Never ending problems
Old Oct 5, 2010 | 01:44 PM
kx250frider617's Avatar
kx250frider617
Default Never ending problems
Well just because its MY truck thinks break one after the other. After spending a bunch of cash on a rear end, now my front end has a knock. I am thinking its the lower ball joint since the boot is ripped or a wheel bearing but I can't figure it out. I jacked up the truck and I can't get re-make the noise by shacking the wheel. Its only over small bumps such as cracks in the road. Its not my shock, nor my tie rod ends. How hard is it to change a lower ball joint or a wheel bearing? I am NOT paying someone to do this job.
Old Oct 5, 2010 | 01:51 PM
kx250frider617
What is the sign of a bad CV axle?
Old Oct 5, 2010 | 02:08 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
sry but 2wd or 4wd? Im assuming 4wd because you said a CV?
Old Oct 5, 2010 | 02:11 PM
kx250frider617
yep 4x4! and why can't carli or kore suspension make a kit for these truck with other accessories. If I have to fix stuff, I hate putting crap OEM stuff back on.
Old Oct 5, 2010 | 02:21 PM
dakota_raven's Avatar
dakota_raven
sway bar links ?
Old Oct 5, 2010 | 02:27 PM
kx250frider617
nope, my sway bar is removed.
Old Oct 5, 2010 | 03:03 PM
dirtydog's Avatar
dirtydog
Moderate User
Do you have leveling spacers on your truck?
Old Oct 5, 2010 | 03:19 PM
kx250frider617
cranked torsion bars and longer shocks but the knock is only on the driver side, my only options are a bad wheel bearing, upper/lower ball joints, or cv axle. I actually just squirted a bunch of grease into the cracks of the lower ball joint boot. If it quiets it down i'll know that its is the lower ball joint. I really don't have the $$ to start replacing stuff so I have to hunt it down and replace it, one at a time. In a perfect world I would just replace it all but I can't do it right now.
Old Oct 5, 2010 | 03:31 PM
dirtydog's Avatar
dirtydog
Moderate User
Have you inspection your inner tierods? They could be causing a clunk.
Old Oct 5, 2010 | 03:54 PM
kx250frider617
Would I feel it in the steering wheel? If I shake the steering wheel i can't feel it. I can only feel it when hitting small bumps and only through my feet.
