ignition switch problems
Old Oct 5, 2010 | 02:51 PM
mbrigman's Avatar
mbrigman
Default ignition switch problems
Anyone know how to change the ignition switch on a 04 dodge ram 1500
Old Oct 5, 2010 | 03:00 PM
dirtydog's Avatar
dirtydog
Moderate User
REMOVAL
SERVICE PRECAUTIONS
NOTE: The steering column on vehicles equipped with an automatic transmission is not equipped with an internal locking shaft with the ignition cylinder. Alternative methods of locking the steering wheel for service will have to be used.
The tilt and standard column (STEERING COLUMN) have been designed to be serviced as an assembly; without wiring, switches, shrouds, steering wheel, etc. Most steering column components can be serviced without removing the steering column from the vehicle.
Safety goggles should be worn at all times when working on steering columns.
To service the steering wheel, switches or airbag, Refer to Electrical Restraints and follow all WARNINGS and CAUTIONS.
WARNING: THE AIRBAG SYSTEM IS A SENSITIVE, COMPLEX ELECTRO-MECHANICAL UNIT. BEFORE ATTEMPTING TO DIAGNOSE, REMOVE OR INSTALL THE AIRBAG SYSTEM COMPONENTS YOU MUST FIRST DISCONNECT AND ISOLATE THE BATTERY NEGATIVE (GROUND) CABLE. THEN WAIT TWO MINUTES FOR THE SYSTEM CAPACITOR TO DISCHARGE. FAILURE TO DO SO COULD RESULT IN ACCIDENTAL DEPLOYMENT OF THE AIRBAG AND POSSIBLE PERSONAL INJURY. THE FASTENERS, SCREWS, AND BOLTS, ORIGINALLY USED FOR THE AIRBAG COMPONENTS, HAVE SPECIAL COATINGS AND ARE SPECIFICALLY DESIGNED FOR THE AIRBAG SYSTEM. THEY MUST NEVER BE REPLACED WITH ANY SUBSTITUTES. ANYTIME A NEW FASTENER IS NEEDED, REPLACE WITH THE CORRECT FASTENERS PROVIDED IN THE SERVICE PACKAGE OR FASTENERS LISTED IN THE PARTS BOOKS.
CAUTION: Do not hammer on steering column shaft. This may cause damage to the shaft or bearing.
CAUTION: Do not attempt to remove the pivot bolts to disassemble the tilting mechanism.
The ignition key must be in the key cylinder for cylinder removal. The key cylinder must be removed first before removing ignition switch.
Remove the negative (ground) cable from the battery.
Disable the airbag, (Refer to 8 - ELECTRICAL/RESTRAINTS/DRIVER AIRBAG - REMOVAL).
Remove the lower and upper shrouds.
Remove key cylinder. (Refer to 19 - STEERING/COLUMN/LOCK CYLINDER HOUSING - REMOVAL).
Disconnect the lower clockspring connectors.
Remove the wire retainer from the tilt lever bracket.
Remove the tilt lever mounting screws to gain access to the ignition switch mounting screws.(IGNITION SWITCH WITH TILT)
For columns without tilt remove the bracket to gain access to the ignition switch mounting screws. (IGNITION SWITCH WITHOUT TILT)
Disconnect the electrical connector at rear of ignition switch (IGNITION SWITCH).
Remove ignition switch mounting screw.
Using a small screwdriver, push on locking tab and remove switch from steering column
This here below is for older Rams, but may help as well??
http://www.dodgeram.org/tech/repair/...ign_switch.htm
Old Oct 5, 2010 | 04:48 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And if you need to know more there are links for the Srvc Mans in my sig link. Just download the one for your truck.
