04 1500 fog lights not working
Old Oct 6, 2010 | 07:10 AM
birddseedd's Avatar
birddseedd
Default 04 1500 fog lights not working
For the life of me i cannot get my fog lights to come on???
Old Oct 6, 2010 | 07:11 AM
HammerZ71's Avatar
HammerZ71
Have you checked the relay? There is also a fuse, could be either...
Old Oct 6, 2010 | 08:04 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And I am going to assume they did work at one time and are not trying to be added on at the time?
Old Oct 6, 2010 | 10:12 AM
dirtydog's Avatar
dirtydog
Moderate User
^^ what Weedahoe said. You CANNOT add foglights and make them work without having the dealer turn on the circuit vis starscan tool. just because the wiring may be there doesn't mean the circuit is live.
Assuming they are factory... Does the foglight illumination icon appear on the Instrument cluster when you turn the headlight control to parking lights and press it in?
No, then your switch could be bad
Yes, then you must have a short at the bulbs or they are BOTH burnt out. Have you checked to see if the bulbs are indeed good?
Old Oct 7, 2010 | 06:33 AM
birddseedd's Avatar
birddseedd
huh, push the switch in, would never have thought of that, though iv got to pull it out to turn them on,
does anyone ever run the fog lights whenever the head lights are on?
