LAMP OUT is driving me Nucking Futs!!!! HID/RESISTOR
Old Oct 7, 2010 | 03:07 PM
RaysRam05's Avatar
RaysRam05
Originally Posted by Smokedlights
Been back and fourth with this to what seems like 100 times, driving me absolutely nuts. Just got new headlights and some different hid bulbs. Took it all out, have a 50w resistor, installed it all on one side, worked good. NO lamp out on dash.. Went to to other side seemed to be good, installed everything put it back together and the **** says lamp out. hids everything work great just cannot live with the light.. I then put it all to stock cut the resistors off, and i still get lamp out, tried to cycle the key, unplug battery and nothing LAMP OUT with stock headlights, and no one of my tail lights is not burnt out. I have a 35w hid kit w/relay harness to battery, 50w resistors hooked up to the low beam side, halogen highs. I dont understand wtf is going on im about to drive it off a cliff
the place i ordered my bulbs from gave me a special dodge harness...they said it was needed to make the computer think it was the OEM bulbs....i got the lights from www.Retro-solutions.com
Old Oct 7, 2010 | 04:22 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And that harness either had caps or resistors in it.
Old Oct 7, 2010 | 11:21 PM
Marx's Avatar
Marx
Originally Posted by weedahoe
^^^ What LEDs do you have? Link please.
got them on ebay searched "3057 LED WHITE", can't remember what store i got them at. Also get the 31 led ones
Old Oct 23, 2010 | 11:25 PM
mark1963's Avatar
mark1963
WEEDAHOE, i just got my new sportiva BI-xenon HID KIT BY GE with the HI/LO HID bulbs for my dodge, i took that cheap set out with those caps. maybe you can help me out, the kit came with a resistor, but they failed to put where to splice the resistor in there instruction book , WOW, i read in another fourm that you don't cut the wire but you use these little clips to install it as an inline between the BALLAST & THE HID BULB, not to cut the factory harness, is this the correct way to install the resistor,???
thanks
Old Oct 25, 2010 | 09:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Those are the same ones I use in my tails and i got mine from ebay also....LOL
Old Oct 25, 2010 | 09:38 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
thanks
What does the resistor look like and yes you can use t-taps or scotch-loks to put them in place. You do not HAVE to cut the wire, solder and insulate.
Old Oct 25, 2010 | 02:10 PM
BadHab1t's Avatar
BadHab1t
what if its the circuit board in your tails? thats trippin that light it did it to me until i replaced the circuit boards.....
Old Oct 26, 2010 | 09:34 PM
mark1963's Avatar
mark1963
well here is where i am with my hid, i solder the resistor from the ground to the low beam, now that my low beam is working my hi/beam is flashing with the lamp out light on as well, now they telling me my 03 ram is part of the 2% of the rams that needs 2-resistors, now i need one between the hi/beam to the ground as well, on my bi-xenon kit, does that sound right,??? this is getting to be a pain in the butt,,
Old Oct 27, 2010 | 12:52 AM
Dolson_Hemi's Avatar
Dolson_Hemi
Just a thought, but the middle bulb in the tails are dual elements (2-way). But a brick on the brakes to make sure the middle ones light up brighter, because they should, or have someone stand behind.
Old Oct 27, 2010 | 06:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Bi-xenon means both high and low beam HID. This means you need one resistor on each beams wire (for a total of two)
Xenon means HID low and Halogen high. Because there is only ONE HID beam (low), you only need one resistor on each side.
