LAMP OUT is driving me Nucking Futs!!!! HID/RESISTOR
Old Oct 27, 2010 | 08:27 PM
  #21
mark1963's Avatar
mark1963
Default bi-zenon, 3rd resistor
i have not yet installed the 2nd resistor and now being told i may need a 3rd resistor in the hanging headlamp harness thats not in use to prevent the lamp-out,, is this true or they trying to sell me another resistor,, i also checked the temp on the one that was installed for the lo/beam, 340. degrees, is this normal,??
thanks
Old Oct 28, 2010 | 08:33 AM
  #22
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you have xenon then you need one resistor on each side (total of two) for the low beam (HID) wires.
If you have bi-xenon then you need two resistors on each side (total of four) for the HID low and HID high beam wires.
Old Oct 30, 2010 | 07:35 PM
  #23
mark1963's Avatar
mark1963
Default resistor temp.
i got everything up and working with my hid. my question now is. i know they say that the resistor gets hot but 400 degrees, i checked it with my temp gun, i drilled and mounted on front cross member, is this temp. normal,???
Old Oct 30, 2010 | 07:37 PM
  #24
mark1963's Avatar
mark1963
i have the same little gold resistor you have in the pics. 50w 6 ohm
Old Jan 19, 2011 | 08:04 PM
  #25
CRAIG02RAM's Avatar
CRAIG02RAM
What's the blue part? Any wired pictures or video
Old Jan 20, 2011 | 02:09 PM
  #26
weedahoe's Avatar
weedahoe
Hall of Fame Member
The blue plug is the 9007 "D" shaped plug that plugs into your OEM head light wiring.
Yes, they will get hot as that what load resistors do. Thats also why they have those little heat sink fins on them. They are made ti dissipate heat. Securing them to the frame is a very good idea.
Old Jan 20, 2011 | 06:50 PM
  #27
CRAIG02RAM's Avatar
CRAIG02RAM
I believe mine are 9008, so if mine run off one side do I need to do anything to passenger side OEM plug?
Old Jan 21, 2011 | 07:47 AM
  #28
weedahoe's Avatar
weedahoe
Hall of Fame Member
2007 DR's have H13 headlight bulbs.
Go to ebay and type "H13 plug" and see what they have. Make sure you get the right male/female plug that you need.
