06 hemi w/mds oil question
Old Oct 8, 2010 | 05:27 PM
groundhogsniper23's Avatar
groundhogsniper23
Default 06 hemi w/mds oil question
hey guys and gals i have an 06 ram and am wondering what weight to use for it. i know it say 5w-20 on the cap and don't want to use something that will screw with the mds system. i want to use mobil one just need to know if its ok to use 10w-30 instead. thanks
Old Oct 8, 2010 | 06:12 PM
freddy53's Avatar
freddy53
if by mobil one 10w-30 you mean mobil one 5w-20 then yes you are right
Old Oct 8, 2010 | 09:42 PM
PETE_YK's Avatar
PETE_YK
Use 5W20 only! The mds solenoids will not work correctly with any other weight. Not sure about an 06, but the 09+ hemi engines will trip an alert and store it in the PCM if the wrong oil is used.
Old Oct 8, 2010 | 10:16 PM
dirtydog's Avatar
dirtydog
Moderate User
Just to give you an idea on how sensitive the MDS system is....I use 5w-30 because I tried to rid the Hemi tick and ONLY because I have the MDS turned of via handheld tuner and the dealer showed me the diagnostic code report when i went in for service on my Instrument cluster. It showed a stored DTC code for incorrect oil weight that only shows up on the Dealers tuner.
Use ONLY 5w-20, 5w-20 or your mds will not function properly and your dealer will know you have the incorrect oil type.
Brand doesn't matter, nor does Synthetic or conventional. 5w-20 is 5w-20 regardless what anyone says. Oil is rated by Viscosity and is how it gets labeled it's weight.
Old Oct 8, 2010 | 11:21 PM
traker1001's Avatar
traker1001
Hmm, I wonder how the PCM senses the different oil viscosity. I bet putting in any kind of cleaner or additive really screws that up. I wonder if it can sense if you put in lighter weight than specified.
With that said I pretty much use 5w20 in just about everything, Its almost the perfect oil weight. Heck I even use it in my garden tractor, Saves from having to purchase different oils. In fact I have a 50 gallon drum of 5w20 Mobile 1 synth in my garage.
Old Oct 9, 2010 | 04:10 PM
groundhogsniper23
thanks guys i am currently using mobil one synthetic 5w-20 and will stick with it thanks everyone for helping me make a big mistake.
Old Oct 11, 2010 | 04:18 PM
Got_Hemi44's Avatar
Got_Hemi44
I use Royal Purple 5w-20
You have a $700 barrel of oil in your garage? Even if you change your oil every 3,000 miles that'll last you like 85k.
Old Oct 11, 2010 | 06:44 PM
traker1001's Avatar
traker1001
Actually it ran me $360+/-, Would of costed less, But I chose to have it delivered. And I change the oil on more than my truck, As I stated I use 5w20 synthetic for everything. Lasts me roughly a year per drum if I try to stretch it. As a plus I find the waste oil burns very clean in my 150,000btu waste oil heater.
Old Oct 13, 2010 | 03:10 PM
groundhogsniper23
traker1001, thats a great way to heat. my mechanic does that is his garage for the winter. u figure all the oil changes he does it will pay for itself inno time
Old Oct 13, 2010 | 03:56 PM
dirtydog's Avatar
dirtydog
Moderate User
Need to heat the place...Just change your oil....lol
pretty nice set-up you got there bud!
