Windshield washer light stays on when filled
Old Jun 2, 2005 | 08:35 PM
Jeff17's Avatar
Jeff17
Default Windshield washer light stays on when filled
For all of you working on CAIs or anything else close to the Washer container, here is something that happened to me.
When I completed my installation of my CAI, my Windshield Washer light would stay on most of the time. I kept using it and checking it for fluid levels to no avail.
I found I had inadvertantly twisted the sender about 90 degrees. It has a float valve inside to check fluid level and since it was sideways, it read empty most of the time. A simple twist back to its original position and all is well.
Old Jun 2, 2005 | 09:26 PM
Drew's Avatar
Drew
Default RE: Windshield washer light stays on when filled
this is deffinately something to remember.
thanks for the tip[sm=smiley20.gif]
Old Jun 2, 2005 | 10:59 PM
osteodoc08's Avatar
osteodoc08
Interesting. I bet it drove you nuts until you found out what was wrong.
Old Jun 3, 2005 | 03:56 PM
Jeff17's Avatar
Jeff17
True - drove me crazy! Just yesterday the "Lamp Out" light started go on and off and a little ding every time it happened. Luckily tomorrow is Saturday and I'll spend some time checking what the heck is going on.
BTW - I noticed a tail light was out this last week. When I was checking it out, I noticed both bulbs were off. I took off the cover and the bulbs were in fine shape. I blew out the connection and put it back together and it worked fine. Anyone else having this happening?
Old Jun 3, 2005 | 04:18 PM
moparturd's Avatar
moparturd
Oops. Good find.
Old Jun 3, 2005 | 06:43 PM
osteodoc08's Avatar
osteodoc08
Jeff17, A good tip is to be sure to smear some electrical grease in the socket (a little goes a long ways) after it has been cleaned out to keep from what you mentioned from happening again. It's always the little things...
