problem with my drive lights.
Old Oct 13, 2010 | 08:35 PM
Denniss66's Avatar
Denniss66
Default problem with my drive lights.
So any ways i hooked up my buddies trailer he uses to move dirt and i knew the lights didn't work on the trailer so i took it to another friends shop to get them fixed. while fixing the trailer lights and checking them i noticed that my back driver side drive lights don't work.
now the wierd thing is when i start my truck with the remote starter the driver side lights work and the passenger lights don't and when i turn the lights on both sides work till i hit the brake or shut the truck off with the remote. the brake lights and signal lights and reverse lights all work but i don't have power for the drive lights.
edit: turns out the whole left side don't work with the lights on and the whole right side front and back don't work with my remote start on.
Old Oct 13, 2010 | 08:57 PM
dirtydog's Avatar
dirtydog
Moderate User
Sounds like a ground issue....BUT, I know there are lots of guys with the PCB board corrosion/melt issue's. I'd pull off your taillights and do a visual on the little computer board that's mounted on the backside of them. They might be either corroded or shorted out.
Old Oct 14, 2010 | 05:58 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah I was going to say the same thing for an 03. They did have those issues on the rear circuit boards.
Old Oct 14, 2010 | 11:32 AM
Denniss66's Avatar
Denniss66
i don't think its the circuit board because i don't have any power at all to the plug. and once i start my truck with the romote starter it works on the driver side. I guess the best but a pain in the *** way to do it is follow the wire.
