RV Tow question
Old Oct 19, 2010 | 09:43 PM
areinike's Avatar
areinike
I thought all 20" wheels had the 3.92's. Just be safe. Regardless, a dry weight of 7150lbs on any 1500, seems a bit high or right at max. Check this site out, it calculates for everything, people, cargo, tongue, etc. http://changingears.com/rv-sec-calc-...eight-tt.shtml. Base what you can tow from your GVWR (i.e. 12,500 lbs.) it'll give you a more accurate estimate versus what Dodge says you can tow with a specific number. It varies depending on cargo.
Old Oct 20, 2010 | 08:16 AM
04HemiGreg's Avatar
04HemiGreg
Originally Posted by dirtydog
The reduction is not due to the tires themselves but rather because the 33" diameter of the 20" wheel/tire combo. That reduces tow by 1,000lbs.
If you have 3:55 gears, your max towable weight is 7600lbs. it's 8500lbs with 3:92's.
Now, that ONLY accounts for a 150lb driver and nothing else. people and cargo add up reeeeeeally quick.
I'd say you would def want a good trans cooler and certainly a Superchips tuner for more advanced transmission support before towing that much weight.
I've got a trans cooler and bought a Superchips tuner earlier this year but it would never successfully program my truck because it kept saying the stock settings weren't stock. Superchips support worked on it for a couple of weeks but was never able to get it to work, so I sold it.
Also, I have the 3.92 rear end with no LSD.
Thanks for the info. I wasn't able to get the RV I was looking at anyway, so I'll keep looking and keep the info in my back pocket...
Old Oct 20, 2010 | 08:32 AM
areinike's Avatar
areinike
There are some nice RVs out there at around 5000 lbs dry - just need to look. I bought a slightly used Trail-Lite 29' with small slide out and it weighs 5200 lbs dry. Was actually looking at something a little shorter (around 26') but couldn't pass up the deal. I did the calculations on that site I posted and with everything I'm about 1127 lbs. under and that's with 10% "margin of error." Eventually I'll get a 2500 with CTD but until then, the little 1500 will suffice for a few more years.
Old Oct 20, 2010 | 10:32 AM
04HemiGreg's Avatar
04HemiGreg
Yep, am aware of that. I had a 31' that was in the 5700 lb range that I sold a couple of months ago. And there are plenty of brand new ones that are nicer, yet even lighter. The RV I was looking at was nice layout and was being auctioned off and would have been a steal at the price I had hoped it would go for. But it ended up being bidded out of my price range so I didn't buy it. It will still be a good deal for someone at the price it sold at but only if everything works and doesn't require expensive repairs. It's been sitting and used as storage for 3 years and it was being sold as-is, so who knows if the fridge or ac or something needs repair. Or if anyone blew out the pipes before letting it sit through 3 winters of freezing temps.
I'd love to have a nice 5th wheel and I know they make a few now that are supposedly half-ton towable. But I'd feel better towing a fiver with a 2500 truck. The problem is, I have no use whatsoever for a heavy duty truck the 90% of the year I wouldn't be towing an RV.
Old Oct 20, 2010 | 11:00 AM
areinike's Avatar
areinike
I hear you there. I think if we had 2500's, we'd use them more than 90%!
