Instrument Cluster replacement?
Old Oct 18, 2010 | 09:57 PM
kartopics's Avatar
kartopics
Default Instrument Cluster replacement?
05' Ram QuadCab --- just had a major short in the instrument cluster...The question is: are the miles (odometer reading) stored in the original cluster? Or I can buy a brand new one and the miles show on it (if they are stored in the ECU? BCM?). Any input would be more than welcome!
Old Oct 18, 2010 | 10:27 PM
brettj2408's Avatar
brettj2408
your odometer is stored in both the cluster (CCN) (cabin compartment node) and the pcm
Old Oct 18, 2010 | 10:54 PM
kartopics's Avatar
kartopics
Does that mean that the mileage would display/show correctly when a new cluster is installed? Or would there be a mis/match error?
Old Oct 18, 2010 | 11:11 PM
dirtydog's Avatar
dirtydog
Moderate User
mileage is stored in the cluster only.
I just had to replace mine and the manufacturer(NOT the dealer) had to program the correct mileage in it. WHile i waited for the new one to arrive, I put 172miles on my old one and there were no conflicting interests between the pcm and the cluster. This is because the cluster has it's own pcm.
If you purchase a used cluster, the mileage that was on the vehicle it was removed from would be the mileage that shows up when you plug it in your truck.
The biggest problem with a used cluster is that it's self-programming to the vehicle it's initially connected to, therfore, if your vehicle has different options, you may have issue's with the cluster working correctly as it gets vin locked to the original vehicle.
A new cluster is about $300 brand new from the dealer and it IS something you can install yourself.
All you need to do is drive to a dealer and have them verify the mileage. Then you can order up a new cluster and it will be programmed to your mileage at the time of verification.
Old Oct 20, 2010 | 04:09 AM
RedTruck-VA's Avatar
RedTruck-VA
Good information. Thanks..
Old Oct 13, 2014 | 06:40 PM
Edmondj25's Avatar
Edmondj25
Default 08 Dodge 1500 Battery drain
Battery drains down if I don't pull the the (IOD) fuse anybody went through this problem or had it fixed.
