Please help!!!!
Old Oct 19, 2010 | 05:18 PM
crazyandy202's Avatar
crazyandy202
Default Please help!!!!
So I am trying to install my 2.5" Top Gun leveling kit and I think i have everything dropped but it wont slid in and I dont know what is going on and cant get this figured out ppllleaase help me!
Old Oct 19, 2010 | 05:21 PM
crazyandy202
Heres another picture
http://s15.photobucket.com/albums/a3...019101613a.jpg
Old Oct 19, 2010 | 05:29 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
So from the second picture it looks like you need to compress the spring to get it to go into place and fit???
hard to tell from the pic.
Make sure you get it aligned after it is all back together
Old Oct 19, 2010 | 05:31 PM
glass3222's Avatar
glass3222
Don't you need to compress the spring to get it in?????
I am not sure, I have torsion bars
Old Oct 19, 2010 | 05:33 PM
crazyandy202
I tried doing that and for the spring is hitting all the way back and it doesnt seem to go far enough backwards
Old Oct 19, 2010 | 11:31 PM
theHemiBeast's Avatar
theHemiBeast
When mine was done, had to use a compressor and it was good to go.
Old Oct 19, 2010 | 11:39 PM
Mega-Hemi's Avatar
Mega-Hemi
Looks like you tore your CV shaft apart, probably not going back together right.
Old Oct 20, 2010 | 12:07 AM
Matt99's Avatar
Matt99
yea you did some havoc on that cv boot, they are hard to get back into the same form as before
You did or didnt try a strut compressor?
Old Oct 20, 2010 | 08:43 AM
dirtydog's Avatar
dirtydog
Moderate User
I dont think the form of the cv boot is an issue, but they are held on by one-time use clamps. hard to tell, but I think you may have sliced the boot at that point which will allow dirt in there. Just make sure the boot isn't sliced. Hopefully the metal band just slid off and you can ziptie the boot back on, but i just dont think thats what happened.
I think if you unhooked your cv shaft on one side, it will allow you to drop the a-arm even more.
Those spacers are very tough to get into place because they really aren't meannt to be placed in the suspension, although several guys do it.
Old Oct 20, 2010 | 10:30 AM
Matt99's Avatar
Matt99
one thing to remember....DO NOT let your brake caliper twist on the brake line....mine is kinked off and am having to get a new brake line cause of it
