Cam For 2006 Dodge 1500 4.7L
Old Oct 20, 2010 | 05:05 PM
meltorres's Avatar
meltorres
Default Cam For 2006 Dodge 1500 4.7L
Hi, I currently have a 2006 Dodge 1500 4.7L 2WD and I really want to get it cammed. I have two other friends that have cammed their vehicles. The problem is I know nothing about it and dont know if they even make one for my truck. If someone knows could they point me in the right direction? Also if you cam your truck will it still pass the state (Texas) inspection? Thanks,
Ethan
Also if you have a cammed dodge let me know what the average cost was for you
Old Oct 20, 2010 | 06:48 PM
HammerZ71's Avatar
HammerZ71
Lot of popular choices out there for the 4.7. Starting with the 4.7 HO cams that I have in my Jeep and going up from there. Keep in mind it takes two cams and anything over the HOs will pretty much require tuning.
AirRam.com is a good starting spot to look at some choices...
Old Oct 20, 2010 | 07:14 PM
rtmtrrdr's Avatar
rtmtrrdr
unless you in a county that requires a smog test,you'll pass
Old Oct 20, 2010 | 08:59 PM
bighornram08's Avatar
bighornram08
Does the ho cams come in the 2008 4.7l already? Ate they the same?
Old Oct 20, 2010 | 09:50 PM
oefootball_70's Avatar
oefootball_70
no, diff cams in the 08
Old Oct 21, 2010 | 02:33 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And then there are those billet cams KRC has
http://axztm.huwab.servertrust.com/P...ode=WPE4.7212R
http://axztm.huwab.servertrust.com/P...ode=WPE4.7218R
http://axztm.huwab.servertrust.com/P...ode=WPE4.7224R
Old Oct 21, 2010 | 07:58 PM
oefootball_70
Those are just reground H/o cams. The billet cams dont need lash caps and wouldnt be labeled as reground
