got a bad shake... help
Old Oct 21, 2010 | 10:03 PM
hoss67's Avatar
hoss67
Default got a bad shake... help
so at 60-65 i have a bad shake, but before or after those speeds no shake at all, i have had the tires rotated an balanced 3 different times, checked all ball joints and tie rod ends and they all seem fine... so im at a loss any advice would be very nice.... thanks
Old Oct 21, 2010 | 10:48 PM
Matt99's Avatar
Matt99
any difference when braking? can you tell if it feels like its from the front or back?
obviously our best guess would be outta balance tires but did they think they were balanced well any of the three times?
Old Oct 21, 2010 | 10:55 PM
oefootball_70's Avatar
oefootball_70
Isn't your level. The 06-08's show trouble with anything more than 2.5 inches of level I thought. Maybe I am off on that. tell me if I am wrong.
Old Oct 21, 2010 | 10:56 PM
oefootball_70
gotta go with a bigger lift now I guess
Old Oct 21, 2010 | 10:58 PM
Matt99's Avatar
Matt99
yea OE but that was more in turns than anything
Old Oct 21, 2010 | 11:39 PM
KUhawkFAN's Avatar
KUhawkFAN
I had the same problem for about 2 weeks right after i rotated my tires. Right at the same mph point (60-65) it would shake like hell. Went away after i put some miles on the again, i figured it was because the tires were cupped and worn differently, whatever it was it doesn't do it anymore, maybe it will again when i do another tire rotation, we will see
Old Oct 22, 2010 | 07:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I had to have my tired balanced 3x before they got it right because I couldnt drive over 70 because the shake was SO BAD.
Old Oct 22, 2010 | 07:47 AM
HammerZ71's Avatar
HammerZ71
When they are balancing your tires, are they ROAD FORCE balancing them?
Old Oct 22, 2010 | 08:25 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I know they didnt do mine that way. I watched them but I was out of town in Miami and didnt want to cause ripples in the water....LOL
Old Oct 22, 2010 | 09:06 AM
HammerZ71's Avatar
HammerZ71
On these larger sized tires, especially ones with higher load ranges, I don't think balancing them is worth a flip unless they are road force balancing them...
