Broken Shock Bolt
Old Jan 20, 2011 | 02:48 PM
Willy McNasty's Avatar
Willy McNasty
To replace the front shocks on 2006 2WD I just have to remove two 13mm bolts (per shock) and slide the shock down?
Old Jan 20, 2011 | 03:42 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If yours has that kinda setup then yes. There is a nut that holds it to the top of the coil bucket also.
Old Jan 20, 2011 | 04:33 PM
Willy McNasty
Thanks, just finished checking out the service manual. Looks easy enough.
Do you know anything about the Bilsteins? I'm pretty much sold on them, but I've heard they're a little stiff (I guess anything compared to stock is)
Old Jan 20, 2011 | 05:23 PM
Ice-Forever's Avatar
Ice-Forever
Yeah, my threads got jacked up when I was taking that bolt out...Luckily I got it out all of the way and I just used a slightly smaller bolt that still caught the threads on the inside, but wasn't so tight that it got caught up on the bad ones, and just put a nut on the back and tightened it up really well with some lock tight. It's been holding just fine.
