FAN CLUTCH problem 2002 Ram 1500
Old Oct 30, 2010 | 12:43 AM
tx08ss's Avatar
tx08ss
Default FAN CLUTCH problem 2002 Ram 1500
I just replaced the fan clutch on my 2002 Ram 1500 4.7L Auto with an aftermarket one. Now there appears to be some drag when I accelerate, most noticeable when the engine has been off for a while. Does anyone know what the problem might be. Thanks in advance for the help.
Old Oct 30, 2010 | 12:55 AM
drewactual's Avatar
drewactual
define 'drag'?
If you mean loss of power, the size, weight, and pitch angle of the blades could very well be robbing you of engine power.. if it's bigger/heavier, or had a steeper angle on the blades you could very well be recognizing the parasitic drag on your engine being greater than the OEM fan...
this is where I beat a dead horse: E-Fan that rascal... I just finished mine a few weeks ago, and as far as performance enhancement, (which is NOT what my aim was by doing it) it is third on my little list of mods that really pay off.. I think I have somewhere around $100 in it..
just my .02...
Old Oct 30, 2010 | 01:42 AM
tx08ss's Avatar
tx08ss
Originally Posted by drewactual
define 'drag'?
just my .02...
I hear a roar around 0-20mph that sounds like the fan is sucking in ALOT of air and then goes away after I gear up.
Old Oct 30, 2010 | 09:27 AM
The Cank's Avatar
The Cank
I am replacing my fan clutch right now. I was thinking about an e fan.... It makes that much of a difference ? what about in the summer when its real hot ? Air Conditioning still kick out cold air ?
Old Oct 30, 2010 | 09:36 PM
drewactual's Avatar
drewactual
It goes away because it clutches as speed increases the flow and cools the coil thingy in the fan. The efan moves just as much air if not more idling stationary as a clutch fan. Mine move a combined 5k cfm. I don't know what the OE CF moves, but I think I got it beat- no matter the ambient temperature. :-)
Old Oct 31, 2010 | 11:54 AM
The Cank's Avatar
The Cank
Ok I replaced mine yesterday and I have the same problem....Big whoosh sound of sucking air and a little loss of power from 0-20. I am not happy about this. Where can I get a good e fan at ?
Old Oct 31, 2010 | 02:51 PM
MikeHTally's Avatar
MikeHTally
The A/C is independent of the cooling fan. My e-fan works great even in 100+ temps. Once you get past 30 mph or so, the fan isn't necessary (which is why they switch off).
Old Nov 1, 2010 | 01:19 AM
tx08ss's Avatar
tx08ss
Everyone I talk to says it's normal, but I just don't remember it feeling that way when I bought the truck new. PLEASE HELP
Old Nov 1, 2010 | 06:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you dont like it then consider replacing it with an electric fan. Getting another new clutch fan is not going to be any different than the new clutch fan you have now. There is a DIY for an e-fan in the FAQs at the top of this section.
Old Nov 1, 2010 | 11:54 AM
The Cank's Avatar
The Cank
Ok I can not find the DIY Faq anymore... am I missing it ? I feel like its right in front of my face
