2500 body lift steering extension
Old Oct 30, 2010 | 06:54 PM
DaytonaDakota's Avatar
DaytonaDakota
Default 2500 body lift steering extension
Installing a body lift on a 2500 and i can't separate the steering shaft. I've done a 1500 and at shaft came out easy this one has nothing to pry against or pull apart
The rest of the lift went great But I'm stuck on separating the shaft for the steering extension
Any help would be great
Old Oct 30, 2010 | 08:15 PM
Matt99's Avatar
Matt99
You need a long extension ( i used a 1 1/2ft breaker bar) and a few extensions and on the end a long socket that would fit over the shaft
get that to where you can hit the end with a BFH and it should collapse on itself. make sure your battery is unhooked
Old Oct 30, 2010 | 08:25 PM
DaytonaDakota
That would work on a 1500. But this is for a 2500 2006
Basically it goes steering box to a female opening with a splined male piece connected
There is nothing to slam or wedge against to slam
