Putting 6" lift on 02 ram 1500 4x4
Old 11-02-2010 | 10:37 AM
Rich 2500's Avatar
Rich 2500
A body lift won't change your drive shaft angles, only have to worry about that with a suspension lift.
Old 11-02-2010 | 01:01 PM
03gsxr's Avatar
03gsxr
Thanks for all the info guys
Old 11-03-2010 | 04:50 PM
03gsxr's Avatar
03gsxr
ok so I went and bought a 3" body lift today should be here on friday so now I know what I'll be doing this weekend if it doesn't rain or snow lol
Old 11-03-2010 | 05:00 PM
Rich 2500's Avatar
Rich 2500
Call friends, buy beer, it's a pretty good job.
Old 11-03-2010 | 05:16 PM
03gsxr's Avatar
03gsxr
Thanks Rich and how do I put a pic of my truck up new to my name?
Old 11-03-2010 | 06:05 PM
Matt99's Avatar
Matt99
if you have any questions you can PM rubberfrog, me, hammer, weed...lol plenty of people to help
Old 11-03-2010 | 06:09 PM
HammerZ71's Avatar
HammerZ71
If it's the PA kit, the docs are excellent...
The only thing I've found with the body lifts is that the lift is a uniform 3" meaning there will still be that rake (nose down) look to the front. Might also want to crank the torsion bolts a bit to level it while you are at it...
Old 11-03-2010 | 09:40 PM
03gsxr's Avatar
03gsxr
Hammer do I have to buy the level kit for that or can I just crank my stock ones to level it? and isn't that bad where you will wear out my front end faster?
Old 11-04-2010 | 12:39 PM
Rich 2500's Avatar
Rich 2500
I guess you figured that out.
Old 11-04-2010 | 12:44 PM
HammerZ71's Avatar
HammerZ71
Any time you put more tension on the torsion bars, you'll stiffen the front end and result in a bit more wear and tear. Despite the claims of level key makers, I've NOT seen where this is any different between cranking the existing keys or installing the leveling keys.
It's all relative and like anything else, in moderation is fine, but don't go trying to get 3" of lift out of a torsion key crank or level. Just a bit 1.5-2" is fine for a nicer, more leveled look and a tad more tire clearance.
Quick Reply: Putting 6" lift on 02 ram 1500 4x4
