clunk when i let off the gas to coast
Old Nov 4, 2010 | 12:11 AM
dodgemudder's Avatar
dodgemudder
Unhappy clunk when i let off the gas to coast
i drive an 05 ram 4x4 with 90,000 miles and sometimes when i let off the gas all the was there is kinda like a clunk or something like that or sounds like the gears catching each other or something. its hard to explain. but i cant tell if its the rearend or tranny or what. you guys have any clue as to what it might be. anything to help me out. and a price range to get it fixed or looked at or anything will help. thanks for any help you guys can give me. thanks
Old Nov 4, 2010 | 05:23 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
When was the last time you pulled your differential covers and cleaned all the old oil out and inspected them and put new oil in?
Old Nov 4, 2010 | 09:11 AM
drewactual's Avatar
drewactual
could very well be a u-joint too... will cost you about $15 for a new one, and about twenty minutes of your time to replace it..
to find out, crawl under your truck and grab your drive shaft, and try to rotate it.. there shouldn't be any play in it at all.. when you turn it one direction the wheels should instantly try to turn, depending which way you turn it depends on which way the wheels try to turn.. if there is any play at all- do this while watching the u-joint.. if there is play in the joint, you should be able to spot it immediately.
Old Nov 4, 2010 | 10:28 AM
dakota_raven's Avatar
dakota_raven
U joint. That is what im thinking of also....
Old Nov 4, 2010 | 08:20 PM
m3summ's Avatar
m3summ
Another vote for the U joint.
Old Nov 4, 2010 | 09:19 PM
meen green machine's Avatar
meen green machine
if im in first gear barely on the gas and let off before it shifts mine makes a clunk. it also happens sometimes from a dead stop. but i had my u joints replaced about a year ago and i had different problems when they went bad. it sounds like mine is coming from the tranny
