Headlight HELP!!
Hey can you guys give me some insight into how to take out my passenger side headlight on my 08 1500 it has moisture in it so i wanna take it out and dry it out then silicon around the edges. also how do i adjust it up and down? its lower on one side than the other when i pull up to a wall
You should find two screws and a rubber flange inboard of the assembly. Remove the screws and the fastener for the rubber flange. Below the assembly and outboard is a bolt. It's a bit difficult to reach, so take care not to scratch the bumper cover.
The vertical adjustment is above the assembly and slightly outboard, I think.
yea two 10mm bolts on the center side of the light. Look under your fender and there will a rubber plug, and there will be a 10mm nut to unscrew
Look behind the rubber strip on the center side of the light and there will be a hole, stick a torx driver in there and turn for vertical-ish adjustment
