transmission solenoid
Old Aug 16, 2023 | 03:30 AM
Skipper0007's Avatar
Skipper0007
Default 65rfe trans
Hello need help, I bought a new shiftpack.and installed it but it's not working, on the dash it's in park but the reverse is lit up, won't shift nothing any help Appreciated
Old Aug 16, 2023 | 01:28 PM
FabricGATOR's Avatar
FabricGATOR
Try to remove the connector and reinstall it. Make sure it is installed correctly.
Make sure the new part is correct.
What is your year, make, model, engine?
Why did you replace this shift pack?
What part number did you install?
Old Aug 16, 2023 | 11:42 PM
Prismatic's Avatar
Prismatic
There's a linkage you need to line up when you install the valve body. Failure to do so can result in some odd behavior or damage.
