Command start acting goofy
Do you have a grey key or a black key. Grey key means you have a factory installed security system that requires a over ride kit. The grey key has a small chip inside that links to the ignition when you start it with the key. Just a thought.
This is a factory RS.
From what it sounds like is it's not getting a signal that the truck has started. Sounds like the starter continues to run after the truck starts. Then it shuts the whole thing off and retries. Again not getting a signal that it's started.
