Command start acting goofy
Old Nov 6, 2010 | 05:44 PM
Geezir's Avatar
Geezir
Default Command start acting goofy
Problem started this morning. I hit the button for the factory command start on my remote and the truck starts. Runs for maybe 5 seconds and then shuts off. Restarts, runs for 5 seconds and shuts off.
Got in my truck and hit the brake to over ride the command start and when starting it with the key the red security light between the speedometer and the temp guage would flash when the truck is running.
Any ideas?
Old Nov 8, 2010 | 12:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can try downloading thr service manuals from the link in my signature and go through the one for your truick and see what you can find. Are you having any issue starting, idling or driving the truck?
Old Nov 8, 2010 | 08:20 PM
Geezir's Avatar
Geezir
Truck runs and starts fine with the key. It's just when I use the remote starter it does this.
Old Nov 8, 2010 | 08:28 PM
Lecrict's Avatar
Lecrict
Something to do with the TACH sens?
Old Nov 8, 2010 | 09:23 PM
Geezir's Avatar
Geezir
Any further diagnosing methods I can try to try and narrow this down?
Old Nov 9, 2010 | 05:23 AM
akguy09's Avatar
akguy09
Default autostart
check the safety switch for the hood, its known prblem with dodge. Its a switch that doesnt allow the vehicle to remote start with the hood open. Sometimes the switch acts up, open the hood and the close it again.
Old Nov 9, 2010 | 06:39 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, the RS is detecting something it doesnt like and shutting down. Or it could be the other way like said above and not detecting something like the hood or door closed or whatever. Either way, it seems it is just related to the RS. Did you get any manuals with it?
Old Nov 9, 2010 | 08:48 AM
Geezir's Avatar
Geezir
I got the dodge owners manual and that...but as far as I saw there was nothing that mentioned anything about the RS.
Two options are bringing it to the dealer and paying $110/hour labor for them to diagnose.....or buying a new system, replacing the POS factory system with a good two way starter system.
Hmmmm...whatever will I do?
Old Nov 9, 2010 | 09:51 AM
dakota_raven's Avatar
dakota_raven
try the hood pin. open the hood and press the pin down with your finger to see if it starts and stay running. i had the same problem more or less. mine just beep the horn and after i checked the pin it was bad. i put a rubber groomet on the top to get more pressure from the hood and problem fixed. the dealer wanted $60.00 for the pin. good luck....
Old Nov 9, 2010 | 06:22 PM
Geezir's Avatar
Geezir
The truck DOES start when I hit the RS. However it shuts off almost immediately and then refires. Shuts off again almost immediately. Then tries to refire again. I've never let it go past this point however.
