Cut outs
Old Nov 7, 2010 | 08:09 PM
mongospaz's Avatar
mongospaz
Default Cut outs
I have been searching the forum for an answer on the single vs dual cut outs on a stock exhaust. I have a 2008 5.7 with the MDS and I am not sure if it will sound like crap or not.
Old Nov 7, 2010 | 08:20 PM
truckin151's Avatar
truckin151
Do single, anything more and it wont run right, well as fast. Unless you are highly modified a dual will actually hurt your performance. Even the single on an all stock vehicle wont perform as good as a buttoned up system. Sound wise you should be fine, dont know how it will sound when the mds kicks in though.
Old Nov 8, 2010 | 02:12 AM
06 Ram5.7's Avatar
06 Ram5.7
DO NOT get a cutout unless you have a programmer to disable the MDS!!! The exhaust sounds bad enough when the MDS kicks in with a muffler, but with a cutout it sounds absolutely horrible. On the flip side, however, if you do disable the MDS, a cutout sounds awesome.
Old Nov 8, 2010 | 10:50 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
How would you do dual cutouts on a stock exh system anyway?
