Old 08-05-2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old 07-26-2011, 01:21 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Go back and read post 84.
If you want to replace them with something then use the 50 watt load resistors as suggested on the first page
  #222
Old 07-26-2011, 10:04 PM
truegent81's Avatar
truegent81
truegent81 is offline
Ok back finally. So first bad news is hidnation won't let me return for a refund. So my question right now is, what lights fit inside the Morimoto projectors? I currently have 9007 OEM but would this fit in the Morimoto?
Who could I speak to about DIY with these projectors? I don't wanna clutter this thread so via email would be good. I just would like to get a list of parts that I would need to go with these projectors. I already have relay and resistor harness but not sure if these are interchangeable. Ordered them with hidnation gear. Thanks
  #223
Old 07-29-2011, 12:06 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Morimotos come in H1 and D2S. PM me your email address for a DIY write up Jermemy did some time back.
9007 will not fit so get H1 bulbs off ebay. D2S will need $15+ adapters.
  #224
Old 08-01-2011, 01:51 PM
FloridaDodge67's Avatar
FloridaDodge67
FloridaDodge67 is offline
i have a question i just got my hids in today they are 9007 bi xenon and came with a relay harness, everything is hooked up correctly the only problem is my high beams they flicker my low beams are fine but my high beams flicker and the lamp out is on
i fix the lamp out with resistors but do i need capacitors for only my high beams?
  #225
Old 08-01-2011, 05:02 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Are you using a total of four resistors (2 per side) or just two resistors total? You should be using FOUR resistors total for bixenons.
  #226
Old 08-05-2011, 03:42 AM
bandroidx's Avatar
bandroidx
bandroidx is offline
thanks for all the great info, i was going to order these:
http://www.hidsrus.com/dodge-ram-150...dlights-bulbs/
(the first set for $57) and saw they are digital ballasts that claim to be flicker free on CANBUS but then they also offer a relay kit for $15 so i was wondering if a) these actually fix the issue and b) why i might still need the relay kit?
Just picked up a 2003 dodge ram 1500, great truck, thanks for the factory service manual weed!
  #227
Old 08-10-2011, 01:26 PM
bayboss23's Avatar
bayboss23
bayboss23 is offline
ight guys so i had a friend order a hid kit for my 2004 dodge ram we had the flickering problem then i bout the things off ebay thay you connect to the ballast i think and suppose to stop the flickering they worked for a while but with time the driver light went out and ive blew my fuse for my driver seat twice.....i took it to a shop and th guy told me when he put them in he put them in wrong and blew a module in the dash and wouldnt recommend hids i like the hid look any other lights that i might be able to use the module was $250 any help would be appreciated thanks
  #228
Old 08-10-2011, 03:48 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Welcome to the site. Why not just connect the HID ballast/harness and resistors correctly and use them. Ive had HIDs for a few years now.
  #229
Old 08-10-2011, 04:34 PM
bayboss23's Avatar
bayboss23
I want to go with halos with a hid kit but the owner of the body shop told me I shouldn't put halos,leds,or hids because I would blow out my front module again
  #230
Old 08-10-2011, 04:37 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
The owner of that shop is an uneducated idiot....seriously. Please stop listening to him
Im sending you a PM
Quick Reply: Got *HID* Problems? Check in here...
