Y-pipe location change?
Old Nov 12, 2010 | 09:48 PM
jdpartsman's Avatar
jdpartsman
Default Y-pipe location change?
As we all know the factory y-pipe is poorly designed and a Magnaflow y-pipe is much better. I have a different idea about the location of the y-pipe, and if it makes any difference at all.
My idea is to remove the factory y-pipe and run two pipes side by side back to my Magnaflow muffler. The pipes would then be joined together with a Magnaflow y-pipe dumping right into the muffler inlet.
Might be a dumb idea.....who knows. It's just what happens when I have too much time to think about stuff. Yah or nah works for me.
Old Nov 12, 2010 | 10:21 PM
brettj2408's Avatar
brettj2408
are you talking a y pipe welded straight onto your muffler (on the inlet side of course)?
the idea of a *Y* pipe is to have it closer to the engine so you dont have to buy 2 sections of lets say 2 foot long tubing to go into the 'y' pipe.
if that makes any sense to you
Old Nov 12, 2010 | 10:36 PM
jdpartsman's Avatar
jdpartsman
yep....I agree.
Old Nov 12, 2010 | 11:24 PM
Duroc's Avatar
Duroc
Ya if you are going to run two pipes that far might as well be into a dual in muffler with no y-pipe.
Old Nov 13, 2010 | 02:03 AM
freestyledude's Avatar
freestyledude
I agree with Duroc. You have dual cats right? on my 03 the cat is part of the y-pipe (kinda)
Old Nov 13, 2010 | 02:09 PM
Lecrict's Avatar
Lecrict
yes, why not just get a Magnaflow muffler with dual in's and pipe from cats straight into the muffler? Any comments on this one?
http://www.summitracing.com/parts/MPE-12468/
Old Nov 13, 2010 | 02:16 PM
jdpartsman's Avatar
jdpartsman
Seems like a few guys have done the di/do muffler thing but if I remember the muffler blows out, or something like that.
Old Nov 13, 2010 | 03:05 PM
chambers's Avatar
chambers
I read the same thing a couple times, I went w/ dual in/single out and haven't had any problems but my truck is a v6. The factory y-pipe on 04's and up is pretty close to the muffler so your initial idea isn't crazy.
Old Nov 13, 2010 | 05:33 PM
jdpartsman's Avatar
jdpartsman
I just thought it would be something different that maybe no one has tried. I have a new SI/DO muffler at home and plan on having my exhaust completely re-done this coming summer.
Old Nov 13, 2010 | 08:29 PM
rovman's Avatar
rovman
On my 03, I have only 1 cat. They Y is just before that. I plan on doing similar to yours ... I will have the Y just before the cat and will re-do the pipes from manifold to Y so that I get more equal length than what it is now.
I just need to determine if there is an ideal location/distance for the pre-cat O2.
