Poor engine performance help
Old Nov 13, 2010 | 11:34 PM
crutcher's Avatar
crutcher
Default Poor engine performance help
Not sure what's going on.
Recently my 2007 1500 4.7L has been running oddly. While accelerating steadily (not heavy) the engine and power kind of cut out for a sec then pic back up then cut out again while coming up to speed 50-60 ish MPH. I have already replaced all of my spark plugs and used some fuel injector cleaner fuel additive. Could it be a vacuum leak? It idles normally no other indications that there is something wrong. Any help is appreciated before I break down and take it to the dealership.
Old Nov 14, 2010 | 10:40 AM
MikeHTally's Avatar
MikeHTally
A vacuum leak would probably throw a code. Have you cleaned the throttle body?
Old Nov 14, 2010 | 04:58 PM
crutcher's Avatar
crutcher
No haven't tried that.
Old Nov 14, 2010 | 05:31 PM
freestyledude's Avatar
freestyledude
while you're in there replace your pcv valve (just a couple $$)
Old Nov 14, 2010 | 05:46 PM
crutcher's Avatar
crutcher
Not sure if it matters but I only have 30,000 miles on it.
Old Nov 14, 2010 | 06:54 PM
MikeHTally's Avatar
MikeHTally
Not sure what the PCV replacement interval is. Us Hemi owners clean ours a few times since they're kinda pricey. A Sea Foam treatment might help, too.
Old Nov 15, 2010 | 12:12 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Any check engine lights lit up?
Old Nov 17, 2010 | 11:49 PM
crutcher's Avatar
crutcher
No lights check engine lights and always starts and idles fine.
Old Nov 18, 2010 | 02:06 PM
broncoremy's Avatar
broncoremy
Don't take it to the stealership. Not yet anyway. Though, I guess it is still under warranty @ 30k miles...
Get a vacuum gauge and check it, the pressure should be steady at idle and roughly 17 to 22 in Hg. You can check it at the brake booster.
Here are some pages for reading the gauge.
http://www.classic-car-magazine.co.u...uum-gauge.html
http://autospeed.com.au/cms/title_Us...3/article.html
