Replaced Coil Pack--Oil Leak
Old Nov 15, 2010 | 03:01 PM
auburnmdw's Avatar
auburnmdw
Default Replaced Coil Pack--Oil Leak
I had a coil pack (3rd one back, on the right side) blow out a couple of weeks ago on my 2003 5.7. After wrestling the remains of the old one out of there and replacing it, I've developed a small oil leak coming from underneath it. What could I have done to cause this? Is there an O-Ring under there that I could have knocked out of place? It's not a major leak, but it is a concern.
Old Nov 15, 2010 | 04:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah there is an o-ring under the valve cover to keep oil out. You might need to pull the VC and inspect/replace accordingly.
Old Nov 16, 2010 | 09:37 PM
horatio102's Avatar
horatio102
I'm not familiar with the Hemi (never owned one) but if it's like most engines these days you've got spark plug tube seals, valve cover gaskets, and valve cover bolt grommets that should probably all get replaced together when you go in there.
Old Nov 17, 2010 | 03:08 AM
abarmby's Avatar
abarmby
Hey auburnmdw. Check this out.
I got these from this company that Weed suggested very recently, while I was on vacation in Florida.
This company is first class and Art is a top man there.
http://www.hensonmotorsports.com/mer...tem.php?id=624
Cant say enough about the help and service!
Hope this helps?
Al
