Help! Line Stripped?
Old Nov 23, 2010 | 08:26 AM
rc51racer30's Avatar
rc51racer30
Unhappy Help! Line Stripped?
Replaced steering rack on 04 Ram 1500. Went fine except I cannot get larger return line to seat into the fitting. It's starts tighting up but the line never snugs up and leaks when I start it. I tried about 30 times and same result. What can I do?
Old Nov 23, 2010 | 09:44 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Do the threads on the hose fitting and rack look good? Are they going in straight? How many threads are you getting to seat until it slips loose?
Old Nov 24, 2010 | 03:50 PM
Veibz's Avatar
Veibz
Any seals inside? I distribute radiators and ac parts and I cannot tell you HOW many returns I get for warranties because of a Leaking oil/transcooler line or Lines popping up compressors and the compressor going bad.
Long story short, 99.8% of these are because they stripped the threads (tightening things with an air wrench without starting it by hand) Lost a seal, or put an O-ring in the wrong spot.
I have never had to deal with a steering rack before but I know this is very common with the parts I have to deal with everyday! I would certainly try to find out if there might be a little seal inside one of the fittings. Good luck
