Alingment?
Old Nov 24, 2010 | 01:44 AM
terracedean's Avatar
terracedean
Default Alingment?
how do i know if i need one on my 08? just put in a 2.5'' leveling kit. drives the same, straight, steeriung wheel stays straight and tires dont make any noise, i also went from 0-80km/h in 4wd and dont have any shake or noise either
Old Nov 24, 2010 | 06:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you leveled the front your alignment is off even if it doesnt pull to the left or right. The toe on the tires could be off. Go get it aligned or AT LEAST take it to an alignment shop and let then check it if you dont believe me.
Old Nov 24, 2010 | 11:48 AM
MikeHTally's Avatar
MikeHTally
When mine was done, the shop said get it aligned, so I did. I think it was off a bit, but may have been before the level. You won't necessarily feel mis-alignment, you'll just notice it in your tires.
Old Nov 24, 2010 | 01:07 PM
Matt99's Avatar
Matt99
like Weed said, you definitely need an alignment after a level
