No hot air!!
Old Nov 24, 2010 | 06:14 PM
timekop's Avatar
timekop
Default No hot air!!
Heater blowing cool air through floor and dash. According to, "Heater Treater", I have a blend door issue. The bd is inside the dash, just left of the glove box area. HT has a better quality metal door for a little over one hundred bucks.
Old Nov 24, 2010 | 06:55 PM
freestyledude's Avatar
freestyledude
That's probably it, it's a common problem with our trucks. I know it's coming soon for me but I'm gonna stall and just the ***** alone for now lol
Old Nov 25, 2010 | 12:44 AM
AF_HEMI's Avatar
AF_HEMI
yep. blend door.
are you full on coolant? check the simple stuff before you spend the dough on bigger stuff
Old Nov 25, 2010 | 03:08 PM
timekop's Avatar
timekop
Yep. Coolant level is good and clean. I'll dig into it tomorrow and take some diy pics as I go.
Old Nov 28, 2010 | 04:02 PM
timekop's Avatar
timekop
Well I took the dash apart only to find the blend door functioning properly. Put the dash back together and did a radiator flush by pouring the Prestone flush in and driving around for the day. Then I took the 2 hoses off at the firewall and blew out the core with air. From that point I ran water through the system. The fluid was filthy!! Repalced with 50/50 antifreeze and distilled water. Results are, run you out heat even on low setting!!
Old Nov 28, 2010 | 06:41 PM
Geezir's Avatar
Geezir
So did that solve your problem?
If it didn't try the dash module. I had a similar problem and picked up a new control unit from a scrap yard and it solved my problem.
Old Nov 28, 2010 | 10:01 PM
timekop's Avatar
timekop
Yep. This problem is solved. Awaiting the next adventure, hopefully later than sooner.
