Power Locks problem
Old Nov 27, 2010 | 10:12 AM
luckydt's Avatar
luckydt
Question Power Locks problem
I have had this issue for some time now and trying to problem solve. When in the truck if i hit the master power lock button on the driver side it will lock only the left side doors. If i go to the passenger side lock button and hit it up to unlock you hear the left side selenoids, but nothing happens. If you hit the passenger lock down nothing happens. Now if i have either passenger door open for more than about 10 seconds the driver side door will lock. This can be a problem if the truck is running and you load something in the passenger side as now you have truck running with the doors locked. I have replaced the lock switch on the passenger side with no luck. So is there something that tells the computer when the door is adjar?
Thanks for the help guys/girls
Old Nov 27, 2010 | 01:09 PM
NYPANAMA42's Avatar
NYPANAMA42
Hey thats a nice color truck....Did you purchase it like that, or did you have a after market paint job done?
Old Nov 27, 2010 | 06:25 PM
luckydt's Avatar
luckydt
It's the factory patriot blue, but the whole truck has been wet sanded and polished to a glass finish so i changes the color a little.
Does anyone know if there are relays that run each side of the power locks?
Old Nov 28, 2010 | 10:54 PM
luckydt's Avatar
luckydt
bump
side note i tried to unlock the truck using the key in the drivers door and the alarm went off had to use the key fob to disarm.
