Low oil issue, need help here
Old Nov 29, 2010 | 06:08 AM
marc00047's Avatar
marc00047
Exclamation Low oil issue, need help here
i check out my oil today to see what the level is and ind went down from 3/4 to 1/2 on the oil stick sooo then i when for a bottle of moble 1 oil and added to it when i openend the add line the top was redish in side the cap and around the seal so i was like what da hell here lately it has also been smoking a lil from the exost and i smell a lot of carben what is going on with my 2003 dodge????????
Old Nov 29, 2010 | 07:18 AM
MikeHTally's Avatar
MikeHTally
The red stuff is often the result of too-short trips. It's sludge (or the beginning). You smell carbon?
Old Nov 29, 2010 | 07:24 AM
marc00047's Avatar
marc00047
well its not really red red its like chocolate brown - red kinda and yes i took it to a mechanic and asked what he smelled and he said carbon when i let my truck idle for a while and take off white blue smoke comes out
Old Nov 29, 2010 | 07:42 AM
marc00047's Avatar
marc00047
sludge on the cap i thought sludge stays at the bottom
Old Nov 29, 2010 | 08:06 AM
Digipenguin's Avatar
Digipenguin
The cap is fine. That is normal.
The blue smoke is burning oil. Could be several things. I'll let the guys who are more qualified take a swing at that one. I would guess rings.
Old Nov 29, 2010 | 08:53 AM
Matt99's Avatar
Matt99
yea the sludge buildup on the cap is common, I believe its something to do with the location. And if you are smoking out the tail end with a white/blue smoke, you have most likely lost a ring. Thats a bigger deal
Old Nov 29, 2010 | 09:24 AM
marc00047's Avatar
marc00047
Default yea
the truck is still under warranty and the dude at the dealer ship keeps telling me use c foam i used three bottles one can each tank and friends tell me the o2 sensor is going out but the check engine light aint on and the truck runs great i had this truck for 2 months and the smoke shows up maby 3 times a week only if i let it idle too long and take off it does it other wise the truck has all the power in the world
