Truck will not start, once in a while
Recently my Ram has failed to start on occasion. When the key is engaged, all of the lights and indicators come on, but the starter does not roll. Initially it seemed as if the transmission was not properly either in park or neutral. I'd move the shifter to drive and then back to park. The truck would then usually start.
A couple days a go it went to a new level. the above did not clear the problem and then the alarm system lost contact with the key fob etc. Had to call AAA for a tow. We disconnected the battery to silence the alarm. At the garage the mechanic started it right up after reconnecting the battery.
Driving it home, I noticed that my Secrity Light would pop on for a few seconds. This morning I put my Super Chip on it to see if there were any codes. There were three:
P0513, Invalid SKIM Key
C2100, Battery Voltage Low
U0168, Lost communications with security system.
I was told that they cleared all the codes at the shop before I brought it home. Other than this it runs flawless.
Any thoughts, Thanks VAN
