Waterpump is Weaping!
Old Dec 6, 2010 | 07:13 PM
rc51racer30's Avatar
rc51racer30
Default Waterpump is Weaping!
Water pump is weaping since it is below freezing here. Reman or New?
Old Dec 6, 2010 | 09:15 PM
mark70669's Avatar
mark70669
New! Always.....
Old Dec 6, 2010 | 10:04 PM
HemiRam1566's Avatar
HemiRam1566
go new, very easy to replace as well, fan shroud, fan, belt.. the overflow bottle comes out with the shroud i believe, remove old pump clean with a razor blade or scraper little brake clean and reinstall.
Old Dec 6, 2010 | 11:09 PM
freestyledude's Avatar
freestyledude
to get the fan off you'll need something to go through the holes on the water pump cover to hold it while you twist the big nut on the clutch fan. I just used a piece of steel with two holes and bolted it on
Old Dec 7, 2010 | 08:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said, new with a LTT warranty.
Old Dec 7, 2010 | 09:31 AM
MikeHTally's Avatar
MikeHTally
Reman, always!
Old Dec 7, 2010 | 12:14 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
For an 04 5.7, www.AutoZone.com has a brand new Duralast water pump (P/N FWP-9303) for $89 with a LTT warranty. Or you can get the remanned ValueCraft (P/N L58-623) for $56 plus $21 (core) but only has a 1 year warranty.
So $89 minus $56 is $33 for that lifetime warranty.
Old Dec 8, 2010 | 07:28 PM
rlfa83's Avatar
rlfa83
New!!! Especially if its from Autozone. My Father is a part-time manager there, on ALL Reman parts - Autozone corp. plans for a 50-60% return on the part due to mis-repair/rebuild.... Amazing, I know - but true.
Im sure you dont want to pull the old one out, install the reman one....an a week later pull it out and do it again - especially in the cold!
Old Dec 9, 2010 | 08:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Last time i changed a water pump was in the winter and cold outside. Me and a buddy did it. We had halogen heat lamps on behind us and I would work for a while and turn around and warm up while he took over. We did this back and forth until we got it done.
Ah.....good memories.
Old Dec 10, 2010 | 12:01 PM
boopadoopa's Avatar
boopadoopa
Got my new pump in yesterday and ill be installing it tomorrow.. Forecast is snow aprox 1-2 inches and cold with a high of 20... Wahoooo.. they always seem to go bad when the weather is bad... Oh well suck it up and do the job... anyone want to help?
