Transmission type
Old Dec 9, 2010 | 10:21 AM
HouseApe's Avatar
HouseApe
You could have a 4 or 5 speed 45RFE or a 545RFE. As you say 45/55/58 (should be 45/55/68)
Fram Part number is FT1223 or FT1223A (this is replacing FT1223)
Old Dec 9, 2010 | 10:22 AM
HammerZ71's Avatar
HammerZ71
I have NO idea what those numbers refer to. The ONLY automatic transmission available on an '06 Ram 1500 would be the 545rfe and to my knowledge there are no "variants" of that transmission.
I have never had to supply ANY auto parts store with any information other than the year and that it's an automatic, EVER...
AC/Delco part number for the filter is TF-102, Mopar part number is M05013470AC if these help you...
Old Dec 9, 2010 | 11:10 AM
Mattis's Avatar
Mattis
Thanks guys! Do I get it right when I understand that there is only one automatic transmission available on the 2006 HEMI 4x4, and that this one is the 545RFE and that the numbers 45/55/68 refer to this one?
I truly appreciate your help!
Old Dec 13, 2010 | 05:06 AM
Mattis's Avatar
Mattis
Can anybody tell me how many quarts transmission fluid I'll need for the fluid change with filters?
Old Dec 13, 2010 | 10:30 AM
HouseApe's Avatar
HouseApe
Service Fill - 45RFE/545RFE
4X2 - 5.2 L (11.0 pts.)
4X4 - 6.2 L (13.0 pts.)
Mopar
ATF+4, Automatic Transmission Fluid or or equivalent
Old Dec 13, 2010 | 11:05 AM
ballmart's Avatar
ballmart
The T-case model is stamped on the T-Case. Its either going to be a 243 model or a 246 model if I'm not mistaken. They take different types of fluid, DO NOT MIX THEM UP!
Also, download weedahoes service manual. Best 9000 pages ever.
If you can't figure out how to change t-case fluid and trans fluid + filter in the ram, you are in for one hell of a terrible experience with ownership.
Old Dec 13, 2010 | 11:10 AM
SeanW727's Avatar
SeanW727
I sent an email to dodge requesting the build sheet for your truck. When they email me back ill be glad to forward a copy to you. Send me a PM so that i have your email. This should help to avoid any future part questions you may have about your truck. (I got mine on thanksgiving day, i thought that was pretty good customer service)
Old Dec 13, 2010 | 11:35 AM
abarmby's Avatar
abarmby
See....that is what this site is all about.
What great help right there.
Al.
Old Dec 14, 2010 | 05:27 PM
SeanW727's Avatar
SeanW727
Never got an email from ya. Heres Your Build Sheet Though.
Thank you for contacting the Dodge Customer Assistance Center with your
build sheet request.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
Sales Code Description
*M9 Cloth 40/20/40 Prem Bench Seat
-D5 Med Slate Gray
AFZ Quad Cab Big Horn Value Group
AHC Trailer Tow Group
APAS Monotone Paint
A55P 5.7L Eng(EZB)/5Spd A/T 545RFE(DGQ)
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRRS 4 Wheel Disc Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CG3S Advanced Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CUSS Overhead Console w/Trip Computer
CVHP Front Center Seat Cushion Storage
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DH5S Elec Shift-on-the-Fly P/Time T/Case
DJMS 205MM HD Front Axle
DMHP 3.92 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
EAGC All Gas Engine
EZB 5.7L V8 HEMI MDS Engine
GACS Tinted Glass Windows
GFDP Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach
JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JRDP Power Driver Seat
JTHP Power 6-Way Driver Seat
K4HP STRIPE/BADGE/MOLDING/COLOR
LMAS Halogen Headlamps
LNJP Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MF1P Bright/Bright Grille
MGAS Ram's Head Badge
MTDS SLT Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCS Front Bumper Sight Shields
MYFP Bighorn Badge
NAS 50 State Emissions
NBEP U.S. Emissions w/OBD 1
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
NHDP Heavy Duty Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PXRA Brilliant Black Crystal Pearl Coat
QXRS Brilliant Black Crystal Pearl Coat
RAAC All Radio Equipped Vehicles
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
RSAP Sirius Satellite Radio
SBAS Power Rack and Pinion Steering
SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TTJP P275/60R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WGAP 20" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
WPAP 20" Aluminum Wheels
XA8S Non Adjustable Pedals
XBSS Pickup Box
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XZ9A Assembly Plant Part Tracking
X81S Instrument Panel Parts Module
X88S Tire & Wheel Parts Module
X95P Call SIRIUS to Activate@888-539-7474
X97P 1-Year Service Provided by SIRIUS
YAAS Build To U.S. Mkt. Specifications
Thanks again for your emai and have a wonderful holiday season.
Old Dec 15, 2010 | 02:21 AM
Mattis's Avatar
Mattis
Thanks a million Seanw727! Great help from the rest of you too! This will make it a lot easier for me to source the correct changeables around here.
