Guage replacement
Old Dec 13, 2010 | 12:00 PM
smooth911's Avatar
smooth911
Default Guage replacement
Last night I had a scare. About 15 minutes before I got off work I started my 05 Ram with the remote start. It was about 10 degrees out and when I left work I put my key in the ignition and took off down the road. I only went a very short distance when I noticed my check guages light was on. I then noticed my oil pressure guage was at zero. I immediatly turned off the engine and started to coast down the road. I then figured, It was running for 15 minutes prior so I'll try to start it again. When I restarted the truck the oil guage was fine. Does anyone know if you can replace just one guage in the dash or do you have to replace the whole dash?
Old Dec 19, 2010 | 04:21 AM
06 RMK 900's Avatar
06 RMK 900
Easy fix
https://dodgeforum.com/forum/3rd-gen...t-attempt.html
