06 Ram 1500 Right Turn Signal Indicator
Old Dec 15, 2010 | 08:27 AM
champr's Avatar
champr
Default 06 Ram 1500 Right Turn Signal Indicator
The right turn signal indicator on the dash does not work. Left works fine. Front and rear turn signals work. Any ideas what could be causing the problem? I have heard, but have not varified yet that the turn signal indicators are LEDs. Is this true or should I try to remove the instrument cluster to replace a bulb. Any help appriciated.
Old Dec 15, 2010 | 12:01 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
It does sound like a bad light but either LED or bulb it will need to be replaced. There are a few threads here where guys have taken out the IC and replaced blown bulbs/LEDs
