Lifted a 2wd, Now I want to go higher. How?
Old Dec 15, 2010 | 08:22 PM
CardinalsFan11's Avatar
CardinalsFan11
Default Lifted a 2wd, Now I want to go higher. How?
I've got a 2008 Ram 1500 2wd. As of now it has the 7" CST Lift; so it has a 4" Lift Spindle, and a 3" Coil Spacer. In the rear, it is a 3" block. I want to go 2-3" Higher, but I don't want to do a body lift. Is there any way to achieve this? I know I can raise the rear by doing add-a-leafs, but how can I go up in the front? I don't understand lifts very well, but would cross-members be of any use? Any help would be greatly apprectiated!
Old Dec 15, 2010 | 08:29 PM
crracer74's Avatar
crracer74
the only way to get more lift in your truck is a 3in body on a cst you cant add a spacer and adding a crossmember would do nothing bc you would have to extend your spindle
Old Dec 15, 2010 | 08:31 PM
crracer74's Avatar
crracer74
i added a 1.5in spacer on to my cst lift and everytime you hit a bump your upper a arm hits the coil bucket no good on the ball joints
Old Dec 16, 2010 | 12:35 AM
Matt99's Avatar
Matt99
yea since you did the spindle lift there arnt many options other than the body lift...why are you so against it?
pics are needed
Old Dec 16, 2010 | 07:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You either got the choices of a body lift or a custom susp lift. But I tell you now, the BL is easier and cheaper.
What size rims and tires do you have on it now?
Old Dec 16, 2010 | 11:50 AM
CardinalsFan11
I just got some 35x12.5x17 BFG Mud Terrain KM2, on 17" Black Rock D Windows.
Old Dec 16, 2010 | 11:51 AM
CardinalsFan11
The reason I'm skeptical about a Body Lift is the fact that I have a grille guard on my truck, and From what I understand, if I do the body lift, the grille guard won't line up like it used to. Is there a way to make that not happen because that's whats holding me back from doing a BL.
Old Dec 16, 2010 | 12:08 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can make it work but would require custom fabrication of mounts and brackets
Old Dec 16, 2010 | 12:23 PM
Matt99's Avatar
Matt99
theres a few guys with body lifts that have grille guards. If you have a grinder and a drill w/metal bits you can fab this up
Old Dec 16, 2010 | 08:23 PM
BadHab1t's Avatar
BadHab1t
still wanna see pics of it before and after....
