Running Hot
Old Dec 16, 2010 | 05:13 PM
MatBert's Avatar
MatBert
Default Running Hot
I have a 2004 2500HD 5.7 and it has been running hot. I changed the thermostat and it is still running at 3/4 on the dashboard gauge. I do have heat and cannot smell anything from the engine. The temp of the air blowing from the heater does go up when driving and down when I stop.
Any thoughts
Old Jan 2, 2011 | 03:27 PM
Altair's Avatar
Altair
Dak attack!
Moving this to 3rd gen Ram, you'll get more answers here.
Old Jan 2, 2011 | 08:28 PM
MikeHTally's Avatar
MikeHTally
Air in the system, maybe? Park it nose up and run with the cap off and heater on 'til it reaches operating temperature. That may burp out any air trapped in the passages.
Old Jan 2, 2011 | 08:29 PM
MikeHTally's Avatar
MikeHTally
Oh, and Welcome to DF!
Old Jan 2, 2011 | 09:34 PM
freestyledude's Avatar
freestyledude
did you test the t-stat before you put it in?
if burping the air a few times doesn't work, radiator may be clogged. I think the pumps okay if it stays steady at a temperature. Could be the clutch fan too, maybe its only coming on at the higher temp now?
Old Jan 3, 2011 | 11:00 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Any thoughts
Normally when i see this i think low coolant level
