fog lights died HELP
So i headed out to PA thursday going up I95 hit all the crappy weather. Stopped for gas just nw of DC and noticed my fog lights had quit. i have checked bulbs but cant find a fuse or relay...... Any ideas .. Please help as im leaving out tonight headed back home and the extra light sure will help.......................
Not sure in an '07 but my '04 has both a relay for the fog lights and a 15a fuse, which are both clearly marked on the inside of the fuse box lid. I think the fuse is for the switch.
I looked in the owners manual and on the lid for the fusebox and neither had a label for a fuse and i see no relays ... Now im pretty mechanically inclined and figured there would be both a fuse and relay but im stumped...
On the '06+ trucks there is also a bunch of fuse boxes on the side of your dash, drivers side. You need to have your door open just to see it. I wasn't thinking about it when you first posted because everything is under the hood on my '04...
There should be a relay under the hood.... Same relay as your starter relay. Swap the two and see if your foglights work or if your vehicle starts...if your fog lights work and ur starter doesnt .. your relay is bad.
Trending Topics
So lights are fixed..... The plug from the truck to the harness that splits to the lights was totally FRIED. I guess dodge doesn't have very good waterproofing skills. That plug @%&t the bed.... Thanks for the help guys!!!!!!!!!!!!!
