Po455
Old Dec 22, 2010 | 06:47 PM
B-2's Avatar
B-2
Default Po455
I had my 03 truck inspectioned today & it failed with the trouble code PO455 is this some thing that Dodge will take care of. Has any one else had this code come up.
Old Dec 22, 2010 | 07:17 PM
B-2's Avatar
B-2
I guess I should have did a search before I posted, looks like it should not be that hard to find. I am not use to working on this new stuff.
Old Dec 22, 2010 | 07:34 PM
HammerZ71's Avatar
HammerZ71
Evap system leak. would be covered under 3/36 but not under the powertrain.
Common things that would cause the code are a bad fitting gas cap, hole in an evap hose or a split at a hose clamp.
There is a "map" of the evap system in the FAQ section...
Old Dec 22, 2010 | 08:13 PM
Boo Radley's Avatar
Boo Radley
yep you got a leak in the evaporator system. check the hose clamps they rust out and fail really fast.
Old Dec 23, 2010 | 08:29 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Check all the hoses under the truck at the evap canister right before the fuel tank. Did you have a CEL on when you went to the inspection?
Old Dec 23, 2010 | 02:39 PM
B-2's Avatar
B-2
Thanks everyone I will check it out after Christmas & let you know what I find out.
Old Jan 1, 2011 | 11:32 AM
B-2's Avatar
B-2
Thanks everyone for the help it was cracked hose & clamp. It runs a lot better & gets better gas milage again. Thanks Bill
