2004 1500 A.C. problem
Old Dec 23, 2010 | 05:17 PM
bobaloochi's Avatar
bobaloochi
Default 2004 1500 A.C. problem
ac and heater will not blow at all. i replaced the blower motor resistor, checked the fuses, and tested the power to the blower motor. i also hooked up the blower motor to an outside power source and it did spin, although very very slowly. when plugged in, the blower motor is getting power. any ideas?
Old Dec 27, 2010 | 12:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ignition switch part of the accessory contacts dont sound to be making contact. Time to replace the ign switch maybe
Old Dec 28, 2010 | 05:30 PM
bobaloochi's Avatar
bobaloochi
could it be the blower motor though? a friend of mine said a few of the coils could be burned or something because he said it should spin full speed if i connect it to a 12v source. just trying to save myself from buying all sorts of stuff before i track down the problem
