3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have a 03 ram 1500 2wd. I have a kit that goes in between the coil springs. The question I have is, I don't have a spring compressor and I was planning on just taking off the 2 bolts that hold on the lower control arm and lowering it just enough to get the spacers in between the springs. Will this work or is there a easier way?
Neither, you are getting the wrong type of spacer. Look at some Daystar spacers and see how they go in. Dont use the ones that go in between the coils.
