I need some help...
Old Dec 29, 2010 | 09:38 PM
crazyandy202's Avatar
crazyandy202
Default I need some help...
Hey, so I am trying to put my leveling kit on. I have got almost all of the bolts off that i need to except for one last annoying one. I cant get the longer bolt that is on the bottom of the shock that the shock swivels on. I got the nut off and after pounding on it i got it to slid out alittle bit but I cant get it out to save my life! This is the only thing holding me up so if you could help me that would be amaaaaazing im desperate!!! Thank you very much!!
CaliDodgeRam's Avatar
CaliDodgeRam
Apply pressure from different angles and then try and hammer it out?
Old Dec 29, 2010 | 09:45 PM
crazyandy202
i beat on that thing from lots of different ways and it wouldnt budge past that point....
Old Dec 29, 2010 | 09:57 PM
CaliDodgeRam
WD-40 if not man I don't know what to say
Old Dec 29, 2010 | 10:13 PM
freestyledude's Avatar
freestyledude
PB Blaster, Torch if you can get it on the threads and not get the shock too hot. Try to spin it with an air gun. That'll usually do it, if not there's some big pressure on that bolt
Old Dec 29, 2010 | 11:42 PM
BToth's Avatar
BToth
Have you used a prybar or large screwdriver to pry upward on the shock to relieve pressure?
Old Dec 30, 2010 | 07:38 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I agree with relieving pressure and I would take a long screwdriver and a hammer and tap it out
