wiring diagram
Old Dec 30, 2010 | 12:15 AM
dinoivie's Avatar
dinoivie
Default wiring diagram
need a wiring diagram for a 2008 ram 2500 diesel for the harness that runs behind the front driverside wheelwell
Old Dec 30, 2010 | 02:08 AM
SeanW727's Avatar
SeanW727
i can get you a wiring schematic for anything on your vehicle... Can you be more specific as to What this Harness controls?
Old Dec 30, 2010 | 07:34 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, kinda need to know exactly what it does to component wise.
Old Dec 30, 2010 | 10:07 AM
HouseApe's Avatar
HouseApe
Not sure what your after but this is the complete wiring info for the 2008 DR
http://www.dodge.com/bodybuilder/200.../dr/drwdmo.pdf
Old Dec 30, 2010 | 12:16 PM
dirtydog's Avatar
dirtydog
Moderate User
That harness plugs into the TIPM and is connected to both the pcm and the IC cluster.
Maybe state what it is you are trying to do and we can point you in the right direction rather than you "free *****" it on your own?
What are you trying to acomplish/add/change?
Old Dec 30, 2010 | 03:18 PM
SeanW727's Avatar
SeanW727
If its with the TIPM... I highlighted where it mentions it in red....
Here ya go...
Old Jan 4, 2011 | 05:42 AM
dinoivie's Avatar
dinoivie
sorry it took a while to get back to you.
it was the c135 pin connector, friend had a blowout and it was pulled apart
had to hard wire it.
thanks for the info.
Old Mar 17, 2021 | 04:20 PM
bentleysmom24@yahoo.com's Avatar
Default 07 dodge no power to lift pump
I need the T.I.P.M pin out sheet
Old Mar 17, 2021 | 05:45 PM
Alex Medeiros's Avatar
Alex Medeiros
10 years after lol...
Old Jan 18, 2024 | 01:34 PM
goodtimeshappen's Avatar
goodtimeshappen
Default 2008 doge ram 2500 diesel
need wiring diagram for all battery cables snd what wires go to the dual relay on side of passenger battery please
