Help with stock Rim match
Old Jan 1, 2011 | 03:30 PM
bowhunter27's Avatar
bowhunter27
Default Help with stock Rim match
Hey all I am the proud owner 0f a Ram 2500 MC. Need to know if i can run 285's on my stock rims not worried about height truck is plenty high as it sits. Just want a wider foot print so i don't get stuck as much. Any input will be greatly appreciated
Old Jan 1, 2011 | 03:47 PM
bowhunter27
Also if anyone can recommend shocks and steering stabilizer stock ones are little warn out
Old Jan 1, 2011 | 07:28 PM
MikeHTally's Avatar
MikeHTally
Welcome aboard. What size rims, 17 or 20? And 285/what? Any should fit. You do have a lot of clearance.
Old Jan 3, 2011 | 05:54 PM
bowhunter27
sorry not height what was i thinking.... width is where im worried. Only think they make 17's with the 8 lug wheels but size is 285 70 r17 just wanna little more width. height is fine clearace on bumpers it good and pumpkins got good distance too
Old Jan 4, 2011 | 11:59 PM
cuervo6767's Avatar
cuervo6767
you should be fine with those. i've got a 2wd 1500 and running a 305/50/20 in the summer and 285/65/18 in the winter with plenty of room. my stockers im running are 275/70/17 if it's a 2500 you should be able to fit up to a 315 as long as your rims are wide enough.
Old Jan 5, 2011 | 06:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, you will be fine. Im running 325's on mine
