Which fuse goes to tpms?
Old Jan 5, 2011 | 01:59 PM
dslofti's Avatar
dslofti
Default Which fuse goes to tpms?
Hey guys I was trying to find out which fuse goes to the tpms so I could just pull it out. The dinging and flashing is getting very old. I swapped out my stock wheels for some 22's but my sensors will not fit int these. I have tryed the method of puttin the sensors in the spare and airing it up. The light will stay off for a little then comes back on. Thanks alot
Old Jan 5, 2011 | 02:11 PM
dirtydog's Avatar
dirtydog
Moderate User
What year is your Ram?
Since you have tpms, I assume it's a later model Ram 06+ that has a tipm fuse bank. If so, the tipm is an electronic bank of relays with some fuses and the tpms is part of the electronic controlled part where there is no fuse. The only control would be a dealer using a starscan tool.
I totally forgot to mention that there are handheld programmers that shut the light off as well. They disable the tpms function but you'd have to spend a couple hundred bucks but you'd get a whole lot more as well.
