Heat problem...
Old Jan 6, 2011 | 10:59 AM
uponone's Avatar
uponone
Default Heat problem...
I did a search and found some information on heat related problems...but non that exactly fit my situation (at least not with an outcome of what the problem was).
My heat has been putting out luke warm air when the truck is stopped. When the truck is in motion it warms up a bit, but not to where it used to be. Temps have dropped drastically around here lately and my 4am drive to work is becoming a bit uncomboftable (and warming up in the truck after a few hours of being outside isn't as satisfying).
All my vents are working the same way (floor, dash, window ect).
Any ideas? Maybe just a clogged heat exchanger (in the need of a backflush)?
If a backflush is suggested, how can I do that? How do I make sure it incorperates my heater?
2003 Dodge Ram 1500 5.7 Hemi
Thanks
Old Jan 6, 2011 | 12:33 PM
dodgeboy1979's Avatar
dodgeboy1979
Does your truck warm up to normal operating temp?
Old Jan 6, 2011 | 02:07 PM
uponone's Avatar
uponone
Yes, the truck does reach normal operating temp. I can even see the thermostat working if I watch my gauge closely. As the truck warms up from a cold start, the needle will rise to exactly midway on the gauge… then the thermostat opens and the needle drops to just below midway. Seems as if the thermostat is working properly.
Old Jan 6, 2011 | 03:41 PM
Rich 2500's Avatar
Rich 2500
Sure your coolent is topped off?
Old Jan 6, 2011 | 04:28 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I also was going to ask if you had checked the coolant level. My dads did this and he was low on coolant
Old Jan 9, 2011 | 06:03 AM
uponone's Avatar
uponone
OK, my coolant wasn't exactly topped off...but it was pretty close. I topped it off and I still have luke warm air blowing out of my vent. It seems to be hotter on the passenger side, especially when I put the floor vents on. But even though its hotter on the passenger side, it still doesn't seem HOT. Maybe I shouldn't be saying hotter...its warmer.
If the blend door isn't working, will air be blowing out of the vents at all? I've heard of people saying they have hot air on passenger side but nothing on driver side...do they mean nothing as in no air blowing or cold air blowing?
Hoping it’s not a blend door and it’s still just a back flush that’s needed.
Old Jan 9, 2011 | 06:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There is a blend door for sale now in the classifieds
Old Jan 10, 2011 | 08:42 AM
Rich 2500's Avatar
Rich 2500
I don't know where the blend door is, but is it possible to move it manually just to see if that is the problem?
Old Jan 10, 2011 | 08:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
It is but wither way you will have to take the dash apart to get to it.
Check out these threads
http://tinyurl.com/28z4tr7
http://tinyurl.com/2b6dexh
http://tinyurl.com/25q8xou
Old Jan 11, 2011 | 08:05 PM
uponone's Avatar
uponone
Thanks guys. I haven't had the time to look into it...I'll let you know once this storm passes! LET IT SNOW!
