bolt pattern 08 -> 05
used to search button a little, saw that all rams 93 and up are on a 5.5 x 5 bolt pattern. just makin sure guys ... 08 stock ram rims will have no trouble at all fittin on a 05 ram?
thanks
thanks
Well, not ANY. You gotta make sure the backspacing is correct; however, any Ram 5x5.5" wheel will fit properly. Nothing changed for the Ram as far as wheels go from 2002-2008 other than the flower pedals were 8.5" wide and the newer 06+ are 9" wide. Backspacing remained the same. 09+ backsapcing is a little greater so may cause clearance issue's on 06-08 Rams with wide tires.
No issue's at all swapping ANY 02-08 Ram wheel on a Ram within those years.
