Oil Consumption???
I have noticed that my past two oil changes (every 3000mi), i have done that my truck would be 2.5-3quarts low. Ive checked and i am 100% certain no oil is leaking on to the ground because nothing is wet underneath the truck, and no spots are ever left
I've been doing some research and it seems like my symptoms could be from a plenum and/or intake gasket that has failed. Is that what it is or is there anything else that it can be?
thanks yall
thanks yall
Yea, by crystal clear i meant it is the appropriate green color with no contaminants. I recently did a flush/fill and even that was clean. No smoke at all really, aside from the normal.
Remove the airhat, open up the throttle blades and look down inside the intake. With that amount of oil usage, you'll probably see a lot of oil puddled on the belly pan. If so, you are the perfect canidate for the plemum fix to replace the blown belly pan gasket and the steel belly pan with an aluminum one.
Trending Topics
Remove the air filter tube off the throttle body and take you a flash light and peek down the TB. You'll see a puddle of oil and/or residue down there. Tell-tale sign of plenum leak.
As I stated above, get the Hughes kit to fix it for good, then get you a Superchips Flashpaq to get rid of the stupid Death Flash (which was Dodge's lame attempt to fix the plenum issue without fixing the plenum issue) and have you like 50 more HP and 60 more TQ!!!
